tt lost power getting on highway
Old May 20, 2007 | 08:42 AM
mexigare81's Avatar
New Member
Default tt lost power getting on highway
I was pulling out of a parking lot and the on ramp was right there so I acc. playfully in 1st. When I went to shift to 2nd I heard a sound like when you vacuum but then something covers the vacuum, that sound. Then my gas pedal wouldn't respond. The car was still idling, radio still on, had power steering, and the EPC light and anti-slip regulation light came on. Does anyone know what this might be, and thanks for trying.
Old May 20, 2007 | 08:47 AM
JustJeff's Avatar
what year, miles? blow a hose?
Old May 20, 2007 | 08:52 AM
mexigare81's Avatar
New Member
2001, 55k, check hoses seemed fine (im no mech tho)
Old May 20, 2007 | 09:09 AM
JustJeff's Avatar
what's it doing now?
DynomiteTT's Avatar
Default Sounds like you had an over boost issue, Vag-com it, You in dallas right?
If you are and dont have a Vag, call carson on Monday at MS performance 2147837480. he'll help you out. btw have you restarted the car yet? try it, if its runs fine, most likely its a boost issue. you've been chipped right?
Andrew
Old May 20, 2007 | 09:43 AM
mexigare81's Avatar
New Member
Default Re: Sounds like you had an over boost issue, Vag-com it, You in dallas right?
it ran fine on the way home and it is chipped, thanks ill give him a call
Old May 20, 2007 | 09:46 AM
mexigare81's Avatar
New Member
Default Re: what's it doing now?
when i jumped on the gas, it sounded like it wasnt getting any air, then the gas pedal wouldnt respond. also the EPC and ASR light came on
Old May 20, 2007 | 10:00 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Sounds like you hit Limp .....>
Soft limp is temporary (unless there is an underlying problem). Could be from a Boost spike, Bad MAF or Temp sensor...Lots of things will cause the Boost to shut down if the ECU isn't getting the info it expects..
 Pouria Savadkouei
 Michael S. Palmer
rasanada
A4 (B9 Platform) Discussion
Dec 16, 2017 07:10 AM
audaciousTT
20
Nov 25, 2004 08:11 AM
coolhand {aka Craig}
Feb 11, 2004 04:01 PM
faust92
Mar 14, 2002 11:50 AM
BukkakeRocky
14
Jun 17, 2001 09:34 PM
