Thermostat leaking?!
Other than the thermostat, what is over on that side that I should look for that could be leaking that much?
Are there any posts that show the replacing of the thermostat? I couldnt find any direct posts.
When I stopped at a light and let the car idle, it would cool down.
If it's really the thermostat, it should do the complete opposite, which is cool down while driving and overheat at idle. That is assuming the fan works.
I didnt know there was a coolant flange too! blah....
Any write ups on the install (replacement of the flange and t-stat?)
(fan seems to be coming on) but not all of the time. Again the issue is when I come to a light - the heat goes up almost immediately. IF there is coolant is the reservoir and I turn the heat on (the temp drops) obviously if it's low it does nothing and keeps rising.
