Help Needed ASAP! Car overheating at dealership
Old May 22, 2007 | 06:15 AM
ALMSTTFLA's Avatar
New Member
Default Help Needed ASAP! Car overheating at dealership
2002 audi tt w/ overheating problem.
Audi has told me a sensor needs replaced that activates the driver side cooling fan. Fan is not coming on so this is why the car is overheating.
167.00 to run diagnostic on car
400.00 for sensor and labor
Has anyone had to replace this part and can i do it myself.
Driving car to Colorado on thurs am so need help ASAP.
Thanks
kerry
west palm fl
Old May 22, 2007 | 06:22 AM
SparTTan's Avatar
Default Some questions
Does the fan come on when the AC is turned on? It's supposed to. If so, turn the AC on when the car starts to get hot.
If the reason for overheating is due to the fan not coming on, the car really should not overheat when you are moving, only when standing still (or moving slowly). How hot is it?
I would think more the thermostat or the water pump could be the culprit. Those are known to fail. How many miles on the car? Have you changed the timing belt (and thus the water pump)?
Old May 22, 2007 | 06:24 AM
JustJeff's Avatar
Default Why not just stay there, let them fix it. Don't tempt fate and drive off. Yes, price is high for....
this, esp. the diagnostics part, but you are right there.
Let the dealer fix the sender, top off the fluid, test the car, and have them be responsible.
If you have never done this yourself, why tempt fate when you are going on a long trip?
Old May 22, 2007 | 06:30 AM
Scenic Driver's Avatar
^^^ 2nd, with a trip coming up this is the best choice
Old May 22, 2007 | 06:42 AM
diehlryan's Avatar
I have a fan problem. Just leave AC on when in stop and go traffic. No overheating here.
Old May 22, 2007 | 06:45 AM
fredfromny's Avatar
Default I would have them do it...
This happened to me and the relay kept shorting out. I had to replace the wiring harness on top of the battery. It took my independent mechanic 4 hrs tracing the wiring to figure this out which he charged me for. The dealer sees these cars all day long and you're getting a warranty as well. You're already there.
Old May 22, 2007 | 07:12 AM
JeffreyTT's Avatar
Default Had the same issue. Dealer had to replace sensor, fan control, and the driver side fan.
Whatever happened, all three had to be replaced. They replaced the fan first as it was dead, but the fan controller was bad and killed the new fan.
Get it fixed as it can cause all sorts of other issues. In my case, the overheating caused the seal around the thermostat to fail causing a loss of coolant.
Old May 22, 2007 | 07:21 AM
Rocky-in-Connecticut's Avatar
Default sounds like a thermal switch on yours... easy fix
the thermal switch in the radiator probably needs to be replaced- the coolant you will need to add after repair will probably cost more $$$ than the switch itself.
 Pouria Savadkouei
 Michael S. Palmer
Old May 22, 2007 | 07:28 AM
diehlryan's Avatar
Replaced green top sensor already. I was thinking Fan Control Module under the battery is bad.
Old May 22, 2007 | 10:56 AM
bubba j's Avatar
AudiWorld Expert
Default Are they really going to charge you for both diagnosis and the repair?
Usually they only charge the diagnostic fee if you don't do the work.
robertjholt
Jul 28, 2017 11:28 AM
ianjax
Audi allroad
63
Feb 25, 2014 07:50 AM
S4ortified
Aug 22, 2006 02:49 PM
Mike Desi
Audi Original "S" Cars
Sep 20, 2004 08:46 AM
Adam Mowafy
Jun 25, 2003 10:31 AM
