Bill Kode: My turn signal relay is working off and on. Did you just spray it w/ electronic cleaner?
Old May 24, 2007 | 04:14 AM
TT twister's Avatar
Old May 24, 2007 | 05:47 AM
kodeTT's Avatar
Elder Member
Default no. the relay itself goes bad. had one go bad in the TT and the allroad. what's it doing?
blinking fast and not at all? you could try to swap out the front turn signal blubs. that fixed my issue with the fast blinking. one was apparently on the way out...caused intermittent blinking.
Old May 24, 2007 | 05:54 AM
JustJeff's Avatar
Default yea, spend all the time to remove it, take it apart, spray it, put it back....still don't work....
throw it out, buy a new one.
<img src="http://www.loomknitting.com/auditt/images/emerswitch.jpg">
second thought" just buy a new one, ~$50
Old May 24, 2007 | 05:57 AM
kodeTT's Avatar
Elder Member
Default just like the cluster, the fuel senders and the relays...
you'd think a simple relay would work as long as you owned the car...but i've had all three go bad on me so far.
Old May 24, 2007 | 06:12 AM
shifTT's Avatar
Junior Member
Default here's a how-to
from the UK forum...<ul><li><a href="http://www.tt-forum.co.uk/ttforumbbs/viewtopic.php?p=809957#809957">http://www.tt-forum.co.uk/ttforumbbs/viewtopic.php?p=809957#809957</a</li></ul>
Old May 24, 2007 | 06:39 AM
JustJeff's Avatar
but it's not the relay itself, but a $0.34 chip
Old May 24, 2007 | 08:56 AM
Seneb's Avatar
Default If it is intermittently clicking, it could be the relay or the turn signal stalk....
I replaced my relay and still had the clicking. I decided to just ignore it rather than buy an expensive signal stalk, pull the airbag, pull the steering wheel, etc.
So, I have my stock relay that is probably just fine if you're interested.
Old May 24, 2007 | 01:04 PM
TT twister's Avatar
Default Bill,once every week or so it won't flash. Just turn on an stay on. Today it happened and I turned
on the hazards for a moment and then tried the turn signal and it worked! What do ya think?
 Pouria Savadkouei
 Michael S. Palmer
Old May 24, 2007 | 02:22 PM
kodeTT's Avatar
Elder Member
i think its the hazard switch...most definitely.
ludachrisA6
Jul 24, 2009 12:31 PM
NOLA TT
Jul 12, 2008 07:56 AM
will_it_dude
Mar 6, 2006 09:11 AM
Mr. Malcontent
Apr 19, 2005 03:52 PM
BMWRider
Feb 27, 2005 09:28 AM
