Electrical Problem!!!
Old Jun 8, 2007 | 03:16 PM
AVSmitty's Avatar
New Member
Default Electrical Problem!!!
I'm driving home from work today and it's 97 degrees. I notice about halfway through my 11-mile drive home that the entire center console (stereo and HVAC) have gone completely black. The little red light that shines down from the center console is still on as is all the electronics behind the steering wheel. The fans kept going, but I could tell the A/C cut out. I tried to turn the fans on/off but got no response at all. When I got home, I noticed there was a high-pitched sound coming from the rear passenger side under the hood (and maybe some kind of fluid spray? I was too pissed off and it was too hot for me to really look). Does anyone have any idea what is going on?
Thanks.
Old Jun 10, 2007 | 01:56 PM
ttspooon's Avatar
New Member
Default Re: Electrical Problem!!!
Welcome to the wonderful world of TT Ownership. One reason I'll never buy another VW/Audi product again. I've had mutiple VW's and have not been driven to drink like owning this car.
I had the same thing happen in a parking lot.
Your AC compressor ate itself. It pushed metal fragments through an overpressure relief and vented the complete charge. While this was happening, somewhere an electrical fault happened that does not involve any fuses.
You'll probably notice that not only does the fan not work, none of the enviornmental systems work either, including the external temp indicator on the instrument cluster. Your power mirrors and defroster won't work, nor will the seat heaters.
I've seen a dealer about this, they replaced the AC control unit and found no change, then suggested that I OK a $2K bill to repair the AC system and similar figure to investigate the electrical issue with a possible substantial increase in cost of labor involved. They couldn't seem to come up with a maximum figure when asked.. (Now really, how much does it cost to replace a wiring harness? Wouldn't that be a reasonable maximum?)
Oh, by the way, Does your radio code out and need to be replaced EVERY time the battery is disconnected? Mine does. Audi of America will replace the radio when it happens within 120 days of a replacement, but they won't figure out why it happens..
joebird
A6 (C7 Platform) Discussion
Jan 7, 2016 04:32 PM
dk8019
Jul 3, 2004 07:06 AM
YAUDI
Oct 8, 2001 11:52 AM
Ash
Jun 14, 2001 08:12 PM
