Power Window issues...need help!!!
Passenger's window wouldn't close/open when using its own power window control. however. passenger's window will only open/close if i use the driver's side window control panel but not with it's own switch. does anyone here experienced the same problem? how to solve it?
another issue, my aibag indicator are all lit. the one in the dash and indicator next to the gear stick "airbag off". I've checked the airbag swith inside the dash compartment and it's turned on. what's causing these stupid problems? im just afraid that my airbag would suddenly explode while im driving.
THANKS FOR THE ADVISE.
vincent
say that its a safety issue...they listen to things that may cause them liability.
