Measuring Block 32 numbers out of spec.
I'm having the darndest time trying to pin point the cause of my car running out of spec. Currently block 32 measurements are (-1.3% to -1.7%) idle, and (-9.5% to -10.4%)partial throttle. MAF values under 2nd gear pulls are between (183 to 195). I checked for vacuum leaks and was unable to find any. I've replaced everything I can think of with little to no change in values. See below.. I'm all out of ideas. Any help would be very much appreciated.
Current setup:
2001 TT 225HP Quattro
Revo Chipped
Modshack Stage 3
-VTDA
-**** (w/ 4bar FPR)
-Boost Machine (Currently turned all the way down - passthrough mode)
Replaced components:
New MAF
New plugs
New Coil packs
-Carlo
Cheers.
Carlo
