bad cluster...?
Old Jun 19, 2007 | 04:29 PM
EmoryDPTT's Avatar
Default bad cluster...?
so i thought that i was overheating the last couple weeks. the temp gauge would be right above 1 tick hot of center. i would pull over to see if the fans were running, but they weren't. did some research on the forums and found the HVAC engine temp read and it never reaches 100 deg C although me temp gauge is high. is the HVAC more reliable then the temp gauge? if so am i starting to see symptoms of a bad cluster? i do have lost pixels on the center display. i also notice that with the car off, the temp gauge is not fully to the cold side, almost 1 tick mark over.
Thanks
Old Jun 19, 2007 | 04:47 PM
GeTT da NeTT's Avatar
Bad gage in the cluster
Old Jun 19, 2007 | 05:24 PM
EmoryDPTT's Avatar
Default you think that it would be safe to assume that...
the HVAC temp is more reliable then the temp gauge?
Old Jun 19, 2007 | 05:39 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Yes
Old Jun 19, 2007 | 05:49 PM
EmoryDPTT's Avatar
Default how would i go about fixing the gauge...?
would i need to replace the whole cluster? either way, i would have to pull the cluster so...? hum
Old Jun 19, 2007 | 05:59 PM
jhoeppel's Avatar
Default Replace the cluster w/new one or have it repaired by somebody like BBA ...>>
I don't know how successful they've been, but follow the link below to see their offer. $250 if you send them your cluster.<ul><li><a href="http://www.bba-reman.com/catalogue/DetailedProduct.aspx?DetailedProduct=196">&lt;link to BBA-Reman TT cluster repair&gt;</a></li></ul>
Old Jun 19, 2007 | 06:26 PM
Steve (Ft. Worth)'s Avatar
Default Try resetting fuses first.
Every time I have a problem with my instrument cluster I pull and replace fuses 11 and 15. This resets the computer. But, be aware that you will lose your clock setting and it will reset the trip meter. Mine's a 2000 TT. I don't know what year yours is or if the fuses are the same.
Good luck,
Steve
Old Jun 19, 2007 | 07:08 PM
EmoryDPTT's Avatar
Default yea, i'll do that, i've pulled those before for something else, so we'll see with this...
thanks to everybody for the replies and i'll keep updates.
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 20, 2007 | 10:04 AM
oTTawaON's Avatar
Default Yes, bad cluster...
I had the same problem a couple of months back. I am now on cluster #3.
Old Jun 22, 2007 | 07:06 PM
gyTT's Avatar
any update? i have similar problem as you.
RKsilver
Aug 21, 2012 08:22 AM
alberttien
Jun 29, 2006 02:40 PM
mtmOla'
Aug 11, 2004 08:38 AM
SpoiledHeeb
16
Jul 21, 2004 11:58 AM
TTeleven
12
Mar 1, 2003 09:43 AM
