why wont my window go all the way up?.....
Old Jun 22, 2007 | 11:44 AM
sims159914's Avatar
Default why wont my window go all the way up?.....
My drivers side window stops about 1/4" from all the way up when the door is closed. This is letting in a lot of wind noise. Any ideas why? It just started about a week ago...could it be the regulator?
Old Jun 22, 2007 | 11:52 AM
whodkne's Avatar
Member
Search for window reset.. highly documented.
ZGTT's Avatar
search for the window reset process. That is what you need.
Old Jun 22, 2007 | 11:54 AM
ZGTT's Avatar
*27 seconds... curses*
Old Jun 22, 2007 | 12:03 PM
whodkne's Avatar
Member
Youth and treachery once again overcomes age and constipation.
Old Jun 22, 2007 | 12:09 PM
sims159914's Avatar
Default Thats not it.....
I tried that and it did'nt solve the problem. The passenger side is fine. The window butts right up against the seal. One touch feature work fine... could it be the window regulator failing on the drivers side?
Old Jun 22, 2007 | 12:43 PM
whodkne's Avatar
Member
Default Are you SURE? I'm pretty sure I'm younger than Bob...
Are you SURE you did the reset procedure? If it is 1/4" below then it's 99% probably the pinch sensor that needs resetting. Especially if the one-touch isn't working on the problem window.
CRU57Y
Apr 10, 2024 06:48 AM
man_utd_4eva_727@hotmail.co.uk
Oct 22, 2016 06:22 PM
Force-1
Mar 23, 2012 10:42 PM
Devius
Oct 19, 2005 11:13 PM
