Transmission & rear diff oil change question...
For fluid transfer, if you have any kind of compressed air and some spare 3/8" hose kicking around, you can easily make a transfer pump. Just take a large jar (I use a 2 quart pickle jar) and poke 2 holes in the lid. insert a 4" piece of 3/8" hose in one and a 3 foot piece of hose in the other, till it reaches the bottom. Seal the hoses at the lid with hot glue. Fill with your favorite fluid and put the long end of hose in the fill hole. Apply the compressed air to the short piece of hose (5psi max) and the fluid will transfer into your tranny\diff.
I have one of those suction guns for fluid transfer but this works WAY better, and much easier to clean - and I can do 2 quarts at a time....
Hope this helps - I can post a picture if requested.
<a href="http://public.fotki.com/DerTT/audi-tt/audi-tt-rear-diff-o/"> Pics of Rear Diff Change</a>
I picked up the fluid transfer pump from the local Pep Boys.
<img src="http://pictureposter.audiworld.com/65932/14mm_hex_fillplug.jpg">
You can also find pumps at auto parts stores that will fit tranny fluid bottles. I tried a couple of them, but they were much more hassle and messier than the above method.
