Boost machine not quite holding boost.... any suggestions will be much appreciated : )
Old Jun 25, 2007 | 04:11 PM
bushido's Avatar
Default Boost machine not quite holding boost.... any suggestions will be much appreciated : )
I recently installed the VTDA, **** and BM. When I started tuning the BM, I noticed that the boost would spike up to 23psi then quickly come back down to 15-16psi. I decided to add 2 shims into my Forge DV with green spring to see if it would help. It seemed to help a little, but still not really holding boost. I noticed that on about 80% throttle, I can sometimes get it to hold 18-20psi for a good period of time. I also noticed that the boost would sometimes "flutter" on higher boost levels (around 20 psi), but this doesn't happen all the time. I suspect a bad MAF from reading all the previous posts, so I've decided to track down a VAG Com to help out. I know about looking at block 32, any other suggestions as to what I should look at? Thanks!
Old Jun 25, 2007 | 04:16 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Give us the block 32 numbers...>
Also do you have a fresh temp sender in there? Lots of things will hold you back on achieving boost. Boost Machnes don't "Flutter" so you probably have something else going in..
Old Jun 25, 2007 | 04:52 PM
bushido's Avatar
Default Running original temp sensor & MAF with 40,000kms. Should I pick up the green sensor from ECS?
Is there a way I can VAG to check temp sensor? TIA!
Old Jun 25, 2007 | 04:58 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Wouldn't hurt..>>
All sensors need to be operating at 100% for max boost!
Old Jun 25, 2007 | 05:11 PM
bushido's Avatar
Is it possible to verify if I need it changed by VAGing?
Old Jun 25, 2007 | 06:00 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Not really..
Old Jun 25, 2007 | 06:01 PM
bushido's Avatar
Thanks, I'll just get a new one in there anyway : )
xr4tic
Performance and Tuning
21
Apr 10, 2004 03:48 PM
X-Pwred225
Oct 25, 2003 07:16 PM
A4ORCE1
Dec 14, 2002 08:52 PM
BLKPERL
Jun 27, 2002 11:02 AM
got_root?
May 26, 2001 12:42 PM
