VWTool and boost questions
<center><img src="http://pictureposter.audiworld.com/14094/boost.jpg"></center><p>using VWTool, I captured my boost values using datablock 115. Here's the 2 questions I have.
1) on the bottom of the graph is time. Around 15 and 60, you can see my boost drop to 0. What causes this? Could it be shift points? I don't remember what I was doing at these 2 points.
2) is there anyway I can capture boost and RPM's at the same time? Having the RPM's to graph would help make more sense of the file.
thanks... josh
thanks... josh
need clarification
<center><img src="http://pictureposter.audiworld.com/8358/dataview.jpg"></center><p>are you using VWTOOL or VAGCOM? If you are indeed using VWTool, you should be viewing your data with the VW "dataview"l that comes with VWTOOL. I've attached a picture of block 115 in the dataview tool. This will graph your RPM, boost and requested boost from datablock 115. Even if you are using the RossTech VAGcom you should see RPM, %, requested boost and actual boost.
CO.Ultra4
02-12-2005 05:24 AM
freeman
13
09-01-2001 03:29 PM
