So wheel spacer question...
Old Jul 13, 2007 | 06:12 AM
diehlryan's Avatar
Default So wheel spacer question...
I've used the calculator and with 8.5 wheels w/ 35 offset and 15mm spacer its showing the rear wheels will be 4mm inside fender.
I have a FWD and based on the 8mm wider rear track on my car I'm assuming my wheels will be flush.. right?
Old Jul 13, 2007 | 10:07 AM
diehlryan's Avatar
Getting no help huh? I guess I'm paying the piper then for last week.
Old Jul 13, 2007 | 12:17 PM
joe@vwvortex's Avatar
Default It will be close.........the calculator isn't that accurate.......
but is a good start. According to the calculator, my wheels should be outside the lip but are clearly not. Honestly 2-4mm is really hard to tell the difference.
Old Jul 13, 2007 | 12:43 PM
diehlryan's Avatar
Default Okay.. so 12.5 front and 15 rear it is.
What is the stock lug bolt length?
Is it right when I assume I'll need 15mm longer lug bolts if I go w/ a 15mm spacer?
Old Jul 13, 2007 | 02:01 PM
Default On the fronts - make sure they are hubcentric and as for the bolts....
yes the rule of thumb is 28mm + spacer size for the bolts. So 40 mm for the front and 43mm for the rear.
Old Jul 13, 2007 | 03:59 PM
diehlryan's Avatar
Thanks. Can't wait to get this done. Along with **** and 4Bar. Then suspension and giac or revo.
ginkof
Aug 6, 2008 09:55 AM
TTALMS
14
Jun 8, 2006 08:08 PM
tt4me2
Jan 17, 2006 08:39 AM
escargot
Audi Original "S" Cars
12
Sep 12, 2004 07:17 AM
