pics of rear main seal???
Old Aug 2, 2007 | 06:43 PM
AudiTTboi's Avatar
New Member
Default pics of rear main seal???
anyone have pics of where the rear main seal is and if its a must to remove the tranny to change out> thanks
Old Aug 2, 2007 | 07:04 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Of course you have to remove the trans...>
It's behind the flywheel and seals the output shaft as it exits the block.
Old Aug 2, 2007 | 07:10 PM
AudiTTboi's Avatar
New Member
Default Re: Of course you have to remove the trans...> see now
i'm confused see the bentley manual calls it the crank seal...now where does it mention the "rear main seal" and from what i remember i didnt see that kind of a seal when i was doing my clutch.
http://ecstuning.com/stage/edpd/pagebuild_v2.cgi?searchstring=crank+seal&searc hqt=byvehicle&make=Audi&model=TT+MKI&s ubmodel=Quattro&engine=225HP
see what i'm saying they have the two seals for both ends of the crankshaft but what about the one called the rear main seal and its in that flange<ul><li><a href="https://forums.audiworld.com/tt/msgs/1669123.phtml#postfp">https://forums.audiworld.com/tt/msgs/1669123.phtml#postfp</a</li></ul>
Old Aug 2, 2007 | 07:54 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default 2 crank seals....>
One at the front of the motor (Harmonic balancer side) and one at the rear (flywheel side..)
4000fixes
Sep 26, 2021 07:43 PM
prijedor
May 12, 2010 02:19 PM
78westfalia
Audi 100 / A6 (C4 Platform)
14
Feb 12, 2008 06:14 PM
a-4cefed
Dec 6, 2006 10:02 AM
markbradford
Apr 1, 2003 02:51 PM
