iceLink to replace cd changer
Thanks a bunch...
Jeff Bipes Site (http://www.loomknitting.com/auditt/install.html) has this to say:
"Rear Seat Removal - TT Coupe.
You'll need a 17-18mm deep well socket to remove the rear seat "striker pin" that anchors the appropriate side's seat back. Not all brands fit.
Now remove the rear seat bottom cushion by pulling up approx. 8" away from either side, in the front. You'll feel one clip on each side that hold it down. Individually yank each side upward with some force and they'll release.
Now remove the bolts that hold the rear seat mounts. As you'll see, you will have to remove the rear seat belt part, too. You will not, however, have to loosen or remove the torx screws--they just hold the seat back mounts in place. Lift the seat back up and slightly to the rear and you'll clear the number 8-shaped be able to remove the seat back."
Also, I found this Audi service doc that seemed useful. It shows how to install the cd-changer. Which is somewhat similar to installing the iceLink to the 13-pin connector, except more complicated.
http://rds.yahoo.com/_ylt=A0geu5sRV7NGx2oAHSlXNyoA;_ylu=X3oDMTE5djExZWo wBHNlYwNzcgRwb3MDMgRjb2xvA2FjMgR2dGlkA0Y4NjBfMTM4B GwDV1Mx/SIG=124h8muic/EXP=1186244753/**http%3a//www.wak-tt.com/tt/tt_docs/tt_cd_coupe.pdf
