Blinkers stopped blinking...>>>
its like 53 bucks.
Run it to your local best buy, they should pop your stereo out for free if they are nice..
Then you just pull the plastic plate down above the stereo, unsnap the little rail that holds the buttons in pull the hazard switch out, reconnect, put the plastic plate back in, push the stereo back in.
Make sure you have your radio code if you disconnect the stereo.
Good luck.
