Update red TT-R:
Old Sep 14, 2007 | 05:28 AM
InTTruder's Avatar
AudiWorld Awesome User
Default Update red TT-R:
- plenty of fuel (known 5g in tank)
- multiple cylinder misfires, C3 and C4 misfiring (per VAG-Com)
I say bring it in.
Old Sep 14, 2007 | 06:08 AM
Scenic Driver's Avatar
Default ...
Fuel in the tank doesn't mean it's getting to the engine. The fuel filter could be clogged, the fuel pump can be failing, the fpr could be bad, etc. If the misfires aren't due to lack of fuel it could be bad plugs, bad coil packs/harness. Also check if the air filter clogged or has a mouse nest in it or something.
Old Sep 14, 2007 | 06:09 AM
Are there any codes stored???
Old Sep 14, 2007 | 07:48 AM
InTTruder's Avatar
Default He didn't "list" the codes, just those named, and I'll have him check all the obvious.
Interesting thing is that it drove well from LI, NY to here. I suspect we'd have seen a degrade (obstruction, filter) earlier. But we'll chase each idea down.
Thanks Evan!
Old Sep 14, 2007 | 08:01 AM
Default One more thing >>>
Hopefully the timing belt didn't jump a tooth.
Good luck. He may end up having to bring it somewhere.
Old Sep 14, 2007 | 08:21 AM
InTTruder's Avatar
Default I think it needs help beyond my ken......
The codes I can read, but diagnosing the ROOT CAUSE is the fun part.
Thanks Evan!
Old Sep 14, 2007 | 09:33 AM
Default A couple more I just thought of >>>
Both of these happened to me
One of the times my MAF went the car would either barely run, run then stall, or not start at all (although there should be codes stored if this were the case).
Same symptoms one of the times my intercooler hose blew off, except for the not starting.
Unplugging the maf in both cases caused the car to work again, in one of the cases I think I had to clear the codes after unplugging it. It's something else to try.
Old Sep 14, 2007 | 04:23 PM
InTTruder's Avatar
Default Fuel rail was dry: fuel pump or FPR I suppose.
Thanks for all the hints!
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 14, 2007 | 04:29 PM
Or the fuel pump relay or a fuse somewhere
Old Sep 14, 2007 | 05:30 PM
InTTruder's Avatar
Checked all fuses, so we'll go for relay and/or pump!
Y888
Dec 17, 2015 11:57 AM
projectsca
Performance and Tuning
Feb 11, 2009 05:13 PM
NickJ
9
Jan 20, 2009 01:37 PM
audix
30v V6 Discussion
10
Jul 14, 2008 11:28 PM
orangedawg
Apr 9, 2007 07:11 AM
