Temp Problems>>
Old Feb 12, 2008 | 04:17 AM
jimmyTT01's Avatar
Default Temp Problems>>
ok car is a 2001 180hp ATC motor...timing belt, water pump, and thermo was done about 15,000 miles. Green temp sensor was replaced about 1yr ago.
Car seems not to want to heat up all the time. Heats up to 1 tick during reg driving. Heater blows warm air not hot. Temp was checked thru the AC controls = 77.
Now this morning driving into work was doing about 70mph then hit stop and go traffic. Car decides to heat up to reg temps per the needle. Heat was warmer, but when start moving back up to normal driving speed the temps slowly go back to 1 tick not in the middle.
I am starting to believe that there is a air bubble in the system or bad thermostat. I have tried to burp the system a couple times but still have the same problems.
Could a thermostat work then not work? Open sometimes and close sometimes?
Thanks
Old Feb 12, 2008 | 04:28 AM
fredfromny's Avatar
I vote thermostat.
Old Feb 12, 2008 | 04:33 AM
GeTT da NeTT's Avatar
Air pockets cause overheating. Based on symptoms, fred is right, your t-stat is wide open.
Old Feb 12, 2008 | 05:15 AM
jimmyTT01's Avatar
thanks that what I was going to go with and replace.
Old Feb 12, 2008 | 05:34 AM
bubba j's Avatar
AudiWorld Expert
Those were my symptoms before I changed my t-stat.
Old Feb 12, 2008 | 05:56 AM
fredfromny's Avatar
Make sure you go with Audi OEM on this part. Good Luck.
Old Feb 12, 2008 | 09:40 AM
JettaTT Love Child's Avatar
Member
Mine is doing the same thing but I haven't the time to fix it right now. Only driving it 2days/wk
sharjeelpk
Q7 MK 1 Discussion
Dec 19, 2020 11:41 PM
a4_sea_pdx
Dec 13, 2007 01:28 PM
nvr_follow
Mar 7, 2007 05:13 PM
boricuaA3
Audi A3 / S3 / RS 3
Nov 12, 2006 01:05 PM
Zdrajca Polski
Audi 100 / A6 (C4 Platform)
14
Dec 10, 2005 05:49 PM
