Any performance gains (obvious. spool faster) with gutting our stock downpipe of the -->
Old Feb 14, 2008 | 06:34 PM
golfindaily's Avatar
Default Any performance gains (obvious. spool faster) with gutting our stock downpipe of the -->
pre cat and is there room to put a couple non foulers on the 02 bung so you can trick the 02 sensor, anyone done it or think it might have some benefits?
Old Feb 14, 2008 | 09:37 PM
Russ Scott's Avatar
Default I think you mean "gut the stock catalyst".. yes?
there's nothing inside the stock downpipe to remove..
I did gut a hi milage factory cat (it had been replaced due to codes)
the good:
the engine made more midrange power... a noticable amount
it ran VERY quiet... there's no increase in noise level at all
the not so good:
compared to the MUCH more substantial power increase produced by a 3 inch down pipe.... the power increase hardly justified the effort
AND, the effort was substantial... it's a b*tch to remove the internals from the cat. It's a VERY robust honeycomb structure. There's no easy way to do it. It took several hours with a low speed, high powered drill and a long 3/4 inch bit to repeatedly drill through and break the honeycomb out of the catalysts... remember, there's 2 small parallel cats in the stock system, so you do it twice
second: 2 non foulers stacked, fit Ok, but they're not enough to stop the CEL's in this configuration. I continued to get "converter low efficiency" codes. Wayne Schmidt's block might do it, though
bottom line: gutting your cat is more trouble than it's worth...
maTTi
Sep 4, 2003 07:48 AM
Coupe_20v
9
Nov 7, 2002 10:35 AM
Ben/A.W.E.
Dec 8, 2001 11:15 AM
BTCC A4
Sep 30, 2001 11:35 PM
BTCC A4
Jul 3, 2001 11:11 AM
