k-mac BT: does anyone have some pdf-instructions for the k-mac
1) Install Kmacs and set to neutral (centered or stock equivalent setting)
2) Adjust Camber with the lower KMAC to desired setting (I like -1.6). You'll be pulling the bottom of the wheel IN here. If you need more adjustment use the top Kmacs to push the wheel OUT at the top.
3) once Camber is set, proceed to toe adjustment.
4)Rotate BOTH top and bottom Kmacs Equally to pull both the top and bottom of the wheel either In or Out to achieve Toe Spec. If no top Kmacs, then the toe must be adjusted with the slotting at the trailing arm pivot point. Use OEM specs for the toe.
5) Double check Camber and tweek if necessary.<ul><li><a href="http://public.fotki.com/ttschwing/kmac_suspension_install/install_pics/">Install notes and pics...</a></li></ul>
