KMAC
Note: Only with a full Kmac set is Toe easily adjustable. Drops of over 1" should install a full set.
1) Install Kmacs and set to neutral (centered or stock equivalent setting)
2) Adjust Camber with the lower KMAC to desired setting (I like -1.6). You'll generally be pulling the bottom of the wheel IN here.
3) once Camber is set, proceed to toe adjustment.
4)Rotate BOTH top and bottom Kmacs Equally to pull both the top and bottom of the wheel either In or Out to achieve Spec.
5) Double check Camber and tweek if necessary.
The folks at Gerbert Audi in Kindsbach or Rittersbacher Audi in Landstuhl speak pretty good english - I never had any problems.
