Air temperature display wackiness
Yesterday and this morning I had no temperature display at all. Later this afternoon there was a value but it said it was -36 deg F! +36 is pretty damn cold for around here
As I drove the value went up, by the time I got to work (around 30 minutes) it had gone up to -18 deg F.Could I have forgotten to connect or cable? Did I bump a cable? The battery was disconnected for about a day if that is any correlation.
I did notice that my display was missing more lines than usual after reconnecting my battery and starting the car - the longer it was on the more that came back - as usual. My RPM gauge stuck for a split second too when I started my car this morning. Looks like I'm probably going to be looking for a cluster soon but I think that may be unrelated. :/
As far as engine temperature readings go... they're perfectly fine.
This will at least tell you of the sensor is working or the Dashpod is having trouble.<ul><li><a href="http://www.wikitt.org/wikiTT/images/f/fc/TTweakers-Guide.pdf">http://www.wikitt.org/wikiTT/images/f/fc/TTweakers-Guide.pdf</a</li></ul>
