Questions about OEM roof rack
Question 1: Does anyone have the instructions for installing the OEM base carrier bars? I received both bars, a wrench, two keys, five bolts, and one washer. Do I need to install washers with each bolt? Any other tips?
Question 2: Can I use the Eschelon carrier with the OEM carrier bars? I haven't removed the Thule bars yet, and it doesn't appear that the bike carrier will fit on the OEM bars.
Question 3: What other bike carriers are compatible with the OEM base carrier bars? (And which ones are the best?)
I would really appreciate any help and advice. Thank you.
It is pretty straight forward though. You open the mounting point covers on the roof, set the bars on top of them, unlock the metal flaps on the bars, screw in the bolts (with a washer on each) and tighten -- 6 Nm I think (not too tight but good and snug).
I've used several different models of the Thule fork mount bike carriers. They all work slightly differently but I have been able to get them all to attach to the bars in one way or another. Basically they all need a t-shaped bolt that slides into the bar and then bolts up through the head of the carrier. I can take some pictures next weekend if you need to get some ideas.
