UPDATE-Tech help Question - Engine code faults
Old Jul 14, 2008 | 10:07 AM
bobbyH's Avatar
Default UPDATE-Tech help Question - Engine code faults
OK here is the update. I had the CEL and the engine code 1136- Runnign too rich ro too lean.
FOUND a broken hose (vacuum leak) We repaired and it was still running a little off. So i purchased the fuel filter and the MAF. Towards the ned of last week the car started to run fine. I never replaced the parts and over the weekend the car CEL went out.
Coincidence? I don't know but thanks to everyone for all the help and suggestions. My fingers are crossed we are back on the road. If not we will replace those items and keep diggin'
234,000+ miles on and I can't quit now!
Old Jul 14, 2008 | 10:27 AM
Badd TT Bone's Avatar
Default when you make a repair cel will clear only after a # of starts
it takes awhile for it to remap, as when you VAG it to clear it would take a couple of starts for the codes to trigger the cel
Old Jul 14, 2008 | 10:29 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Just took a while for your fuel maps to adapt after the fix..
You could have sped that along by dumping the ECU eprom memory (disconnecting the battery)
tmanley
Jan 22, 2010 11:58 AM
Blue2
Jul 3, 2008 07:26 PM
BoostMaster
1.8T Discussion
Dec 30, 2006 06:10 PM
Replayrn
Feb 23, 2006 06:55 PM
Texas Twin T
Sep 10, 2004 04:36 PM
