Diamondite Headlight Restoration Kit
Old Jul 16, 2008 | 12:21 PM
ClarkSJ's Avatar
Default Diamondite Headlight Restoration Kit
Inspired by the recent post (which I have forgotten was by whom)concerning professional headlight restoration, I decided to try the Diamondite headlight polishing kit on the HIDs on my Passat. These headlights are OEM Euro-HIDs that I bought used a couple of years ago. I did a wetsanding technique on them before install as they were a bit pitted, and they had gotten dull over the past six months or so.
The Diamondite kit has two small foam pads (yellow and orange) and a Velcro backing plate for a handheld drill. You can get an adapter for a Porter-Cable polisher also. It has two levels of polish and a spray-on sealant. You polish as with a detail polisher, at 1800 RPM or so, using each of the pads with the appropriate polish. Then wipe clean and spray on and buff the sealant. Let the sealant cure for an hour and hit it with another spray and buff.
I did both headlights in about 30 minutes total, after masking them off and cleaning with Windex. The results were very smooth and much better than my previous wetsanding. I'm curious as to how well they'll hold up, but even doing this every 6 months or so would not be too burdensome.<ul><li><a href="http://diamondite.com/diamondite-clear-plastic-kit.html">Diamondite</a></li></ul>
Old Jul 16, 2008 | 12:26 PM
PracTTical's Avatar
could you post pictures of the results? i'd really like to do this soon
Old Jul 16, 2008 | 12:45 PM
ClarkSJ's Avatar
Default Sure, but the headlights are so clear there is not much to see <g>
I'll take some and post tonite
Old Jul 16, 2008 | 01:24 PM
PracTTical's Avatar
thanks!
Old Jul 16, 2008 | 01:30 PM
BlueChip's Avatar
Seeing nothing is seeing a lot.
Old Jul 16, 2008 | 04:15 PM
carsluTT's Avatar
Default wonder how that would do w/ a lill high quality clear coat sprayed on
after ur all done w/ removing teh scratches/pits and such.
Old Jul 16, 2008 | 05:56 PM
ClarkSJ's Avatar
Maybe pretty good if the CC will adhere and not yellow
snesheim94
Auto Detailing Discussion
Dec 27, 2017 08:28 AM
Flint'sA6
Jun 23, 2008 08:42 AM
CHIZEN
17
Feb 9, 2005 08:26 AM
BSCA4
Jul 14, 2004 09:32 AM
vrsix
Sep 10, 2000 10:36 AM
