checking haldex unit
I drove in a circle up to 10mph and then disengaged the clutch....once without reving the car and once with.
When I was revving the engine the car didn't go as far as when I wasn't, but out of four tries, it only went half as far once. Could this mean the the haldex is only partially engaging or are things ok with the unit?
Lance
Go out in a dirt surface and do a clutch dump. If the front wheels spin you have a problem. If it hooks up you are likely OK..<ul><li><a href="https://forums.audiworld.com/tt/msgs/1452481.phtml">Haldex diagnostics..</a></li></ul>
