MMI Bad ? 07-Control Head ERROR - ERROR
Thursday,18,October,2012,21:08:15:42396
VCDS Version: Release 11.11.4
Data version: 20120807
Control Module Part Number: 4E0 910 468 A
Component and/or Version: Gateway H07 0040
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head ERROR ERROR
0E-Media Player 1 OK OK
47-Sound System OK OK
56-Radio OK OK
37-Navigation OK ERROR
56-Radio OK OK
May be something else in there to point us in the right direction.
It's probably not a fuse if it comes and goes like that.
My gut feeling is a bad electrical connection, optical loop issue, or stuck MMI control.
Did anything lead up to this (spill, dead battery, installing something) or did it happen out of the blue ?
ETA: Welcome to AudiWorld ! Lots of great folks with a ton of information here.
thanks folks
Thursday,18,October,2012,19:52:49:42396
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E64N018885 Mileage: 140720km/87439miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 1110
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 1010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0532699
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: D8BFCA5A6BB677D8B95
Part No: 4E0 905 852 C
Component: ELV 1734
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 14
Reset counter: 73
Mileage: 140016 km
Time Indication: 0
Date: 2012.09.30
Time: 13:06:14
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 83
Mileage: 140544 km
Time Indication: 0
Date: 2012.10.13
Time: 15:22:24
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:54
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 02313 785 00200
VCID: 23452DB6E27064001C7
No fault code found.
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000034693
Coding: 1085761
VCID: DABBD05215BA65C88F1
1 Fault Found:
01869 - Left Rear Cold / Warm Air Outlet Motor Position Sensor (G351)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 11
Reset counter: 82
Mileage: 140045 km
Time Indication: 0
Date: 2012.10.04
Time: 13:29:20
Freeze Frame:
Voltage: 13.50 V
(no units): 147.0
(no units): 255.0
Address 09: Cent. Elect.
Cannot be reached
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012241
VCID: E5C1F3AE2CC4DA30323
Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 73
Mileage: 140026 km
Time Indication: 0
Date: 2012.10.01
Time: 08:00:30
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 140552 km
Time Indication: 0
Date: 2012.10.13
Time: 15:22:25
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D0005502
Coding: 0016233
Shop #: WSC 01107 067 57207
VCID: DCB7D64A1F8E9BF89DD
1 Fault Found:
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 69
Mileage: 140026 km
Time Indication: 0
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 020050410712D3
Coding: FCFE7BDD1B2304
Shop #: WSC 01107 444 52994
VCID: 264334A2914291287B9
4 Faults Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 56
Reset counter: 88
Mileage: 140026 km
Time Indication: 0
Date: 2012.09.30
Time: 12:05:28
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 140552 km
Time Indication: 0
Date: 2012.10.13
Time: 15:10:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 140552 km
Time Indication: 0
Date: 2012.10.13
Time: 15:22:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 140606 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:51
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV 1734
4E0905852C ELV 1734
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 73
Mileage: 140016 km
Time Indication: 0
Date: 2012.09.30
Time: 13:06:14
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 83
Mileage: 140544 km
Time Indication: 0
Date: 2012.10.13
Time: 15:22:24
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:54
Address 34: Level Control
Cannot be reached
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
2 Faults Found:
01877 - Belt Height Adjustment Button (E333); Down
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 2
Reset counter: 48
Mileage: 140372 km
Time Indication: 0
Date: 2012.10.07
Time: 00:13:37
01876 - Belt Height Adjustment Button (E333); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 48
Mileage: 140372 km
Time Indication: 0
Date: 2012.10.07
Time: 00:13:37
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM007 0110
Coding: 0028196
VCID: DEB3DC42099289E8F39
3 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.01
Time: 15:31:24
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:52
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000031381
Coding: 0010111
VCID: 1E331C42C91249E8339
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 83
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 73
Mileage: 140048 km
Time Indication: 0
Date: 2012.10.06
Time: 10:00:00
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 69
Mileage: 140024 km
Time Indication: 0
Date: 2012.10.01
Time: 08:00:00
00046 - Left Headlight Washer Jet Motor (V248)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 48
Mileage: 140048 km
Time Indication: 0
Date: 2012.10.06
Time: 11:53:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 18
Reset counter: 69
Mileage: 140000 km
Time Indication: 0
Date: 2012.09.28
Time: 14:40:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:52
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 65: Tire Pressure
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 75: Telematics
Cannot be reached
Address 76: Park Assist
Cannot be reached
End ---------------------------------------------------------------------
If yes, I would be inclined to get a full charge on the battery (replace if more than 5 years old) as a starting point. The MMI misbehavior shouldn't be an issue when driving the car, but low batteries have been know to do all kinds of weird things with the electronics of these cars.
Carry on...
HERE IS A FRESH SCAN WITH CAR RUNNIG
Saturday,20,October,2012,13:02:42:42396
Chassis Type: 4E0
VIN: WAUML44E64N018885 Mileage: 140770km/87470miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D0532699
Coding: 0007773
VCID: 1F4D2146CE1840E038F
1 Fault Found:
18282 - Valve for Torque Support Mount
P1874 - 001 - Short to Plus
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0029175
Coding: 0000002
VCID: 24472EAAE77E633865D
1 Fault Found:
18156 - Transmission Control Unit
P1748 - 000 - Programming Error - Intermittent
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 109.0
Temperature: 18.0°C
T.B. Angle: 0.0°
Voltage: 11.44 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 N
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224B28B2FD6A6D08171
Coding: 0263168
Component: ELV 1734
Coding: 3940448
Cannot be reached
Coding: 1085761
Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Component: Sitzluefter BFS H02 010
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 82
Mileage: 140045 km
Time Indication: 0
Date: 2012.10.04
Time: 13:29:20
Freeze Frame:
Voltage: 13.50 V
(no units): 147.0
(no units): 255.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Component: ILM Fahrer H12 0170
Coding: 0123113
Shop #: WSC 01814 444 53366
VCID: 2C57C68A8FAEAB78ADD
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H40 0380
Coding: 00000035
Shop #: WSC 01814
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 01814
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Coding: 0012241
Coding: 0016233
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 69
Mileage: 140026 km
Time Indication: 0
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 51
Mileage: 140776 km
Time Indication: 0
Date: 2012.10.20
Time: 12:52:29
Coding: 0263168
Component: ELV 1734
4E0905852C ELV 1734
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 254133AEEC449A30723
Coding: 4071522
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 51
Mileage: 140372 km
Time Indication: 0
Date: 2012.10.07
Time: 00:13:37
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 51
Mileage: 140372 km
Time Indication: 0
Date: 2012.10.07
Time: 00:13:37
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000401400087
Coding: 0003477
VCID: 1D311B4EC41452F02A3
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.01
Time: 15:31:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:52
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040401120142
Coding: 0065086
VCID: 275D39A69648882040F
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Cannot be reached
Coding: 0010111
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:52
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 01107 444 57240
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Time Indication: 0
Freeze Frame:
Voltage: 9.52 V
Count: 61
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: E2CBE8B23DEAAD08D71
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000196628
Shop #: WSC 01107 444 00749
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1311270519
Coding: 303030393135313035414B56413031333131323730353139
Shop #: WSC 00000 128 00289
5 Faults Found:
02277 - Quiescent Current Stage 6
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 69
Mileage: 140026 km
Time Indication: 0
Date: 2012.09.29
Time: 09:13:11
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 140026 km
Time Indication: 0
Date: 2012.09.29
Time: 03:06:34
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 71
Mileage: 140026 km
Time Indication: 0
Date: 2012.09.29
Time: 07:07:55
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 71
Mileage: 140026 km
Time Indication: 0
Date: 2012.09.29
Time: 09:12:36
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 29
Mileage: 140414 km
Time Indication: 0
Date: 2012.10.08
Time: 22:02:26
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: DDB1DB4E049492F0EA3
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: DFCDE1460E9880E0F8F
3 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 140026 km
Time Indication: 0
Date: 2012.10.01
Time: 08:01:34
Freeze Frame:
Speed: 255.0 km/h
Voltage: 8.10 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 148
Reset counter: 51
Mileage: 140049 km
Time Indication: 0
Date: 2012.10.06
Time: 10:00:26
Freeze Frame:
Speed: 0.0 km/h
Temperature: 18.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 29
Mileage: 140013 km
Time Indication: 0
Date: 2012.09.28
Time: 15:21:09
Freeze Frame:
Speed: 49.0 km/h
Temperature: 16.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.01
Time: 15:31:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 69
Mileage: 140016 km
Time Indication: 0
Date: 2012.10.02
Time: 07:25:44
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 140592 km
Time Indication: 0
Date: 2012.10.13
Time: 21:25:52
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3007926
Coding: 0000005
Shop #: WSC 00672 564 45725
VCID: E0CFE2BA30E6BF18C15
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402100786
Coding: 0001208
VCID: 214927BEF86C76100EB
ANY ADVICE. I COULD PROBABLY SCAN AGAIN & GET DIFFT RESULT === > ACTUALLY JUST DID TRY AND RUN AGAIN AND THE SCAN HANGS IT DOESNT COMPLETE (JUST TRIED 3 DIFFET OCCASIONS 7 OPTICAL SCAN HANGING
Saturday,20,October,2012,13:28:29:42396
19-CAN Gateway OK ERROR
0E-Media Player 1 OK ERROR
47-Sound System OK ERROR
56-Radio OK ERROR
