If I am replacing ball joints and then getting an alignment done, should I torque the nuts to spec?
Old Sep 9, 2008 | 09:48 AM
SparTTan's Avatar
Default If I am replacing ball joints and then getting an alignment done, should I torque the nuts to spec?
I believe the ball joints use the one-time use bolts. (The Bentley manual says to replace the hardware each time.) If they need to be loosened in order for the shop to adjust alignment, should I not tighten them down all the way? The alignment shop is about a mile from my house, so if I wrench them down tight but not completely to the torque specs, should I be OK to drive the car to the shop?
Not sure if those nuts are the loosen-tighten repeatedly kind.
Old Sep 9, 2008 | 09:50 AM
JohnLZ7W's Avatar
Default I torqued mine, was surprised to see that they're supposed to be one-time use parts
I've had the control arms on and off a bunch of times and always just torque them to spec (55ft lb I think).
Old Sep 9, 2008 | 10:03 AM
DumpTTruck's Avatar
Default I believe it's replace every time you replace the joint >>
I'd torque them down to spec for the drive. It'd be bad if they came loose. Real bad probably.
Old Sep 9, 2008 | 11:05 AM
BlueChip's Avatar
Default They are NOT one-time use parts.......
You are doing it right.
BC
Old Sep 9, 2008 | 11:14 AM
JohnLZ7W's Avatar
Interestingly the new parts I got had 1mm larger nuts than my factory parts
Old Sep 9, 2008 | 08:06 PM
SparTTan's Avatar
If that's the case, why does the Bentley manual say "Use new nuts" when installing?
Old Sep 9, 2008 | 08:08 PM
JohnLZ7W's Avatar
the bentley people own the nut factory?
Old Sep 9, 2008 | 09:10 PM
DumpTTruck's Avatar
Default My new joints came with new nuts. I think thats all they mean >>
Not every time they are loosened. Just when you get a new joint.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 10, 2008 | 11:17 AM
SparTTan's Avatar
Yep actually mine did too (and I also unknowingly ordered new nuts along with them)
Bowie Anderson
11
Mar 13, 2017 06:17 AM
B5QShip | CFDQ
Mar 22, 2007 07:04 PM
AudiTTboi
11
Oct 25, 2006 08:37 AM
CvTech
24
Jun 2, 2006 05:57 PM
