Evans NPG+ Waterless Engine Coolant
It's a good thing it has a higher boiling point, since that makes it much more likely that you'll need it. You would have to pump much more of it through the engine to remove the same amount of heat as standard coolant, and its higher viscosity makes that difficult.
