Low engine coolant indicator
Old Apr 7, 2008 | 12:24 PM
NickAudiA4's Avatar
Default Low engine coolant indicator
The low engine coolant indicator came on, on my Audi A4, 2002. I thought that the cooling system is sealed. Does it mean that I might have a leak?
I checked the engine and indeed the coolant is below the min line.
Also does anybody know where I can get engine coolant liquid for Audi's? The dealer only sells 1-gallon bottles, which is way more than i need.
thanks in advance
Old Apr 7, 2008 | 12:31 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: I thought that the cooling system is sealed...
It is, up to a specified pressure...usually 18-24psi, then the cap on the res will vent to atmosphere. It will also vent during cooldown, so loss of a small amount of coolant is normal over time...
Bite the bullet, buy the gallon, filler back up. Store whats left of the gallon in your garage for next time, or for a friend. ;o)
Old Apr 7, 2008 | 01:13 PM
skeeball's Avatar
Member
You can also top off with distilled water.
Old Apr 7, 2008 | 03:19 PM
character zero's Avatar
Default my guess is you have a leak....
I know I'm jumping to conclusions a little but if you have a 1.8T it's prolly at the elbow on the back of the cyl head- if you haven't changed it already ;-) Mine's an '02 and I just changed it.
Are you smelling coolant yet?
Old Apr 7, 2008 | 04:52 PM
NickAudiA4's Avatar
Default Re: my guess is you have a leak....
there is no coolant smell, at least not yet.
I guess I will just replenish it and keep my eyes on it.
Old Apr 13, 2008 | 08:15 AM
rs4tech's Avatar
Default Re: Low engine coolant indicator
There is an sealing plug in the block where the thermostat bolts up. it leaks a lot but all you need is a new o-ring to fix it
jeffkruse
Dec 16, 2021 05:59 PM
Boosted01tt
1.8T Discussion
Jan 3, 2017 05:55 PM
ECS Tuning-Audi
Sep 3, 2015 12:45 PM
giuseppepat
Sep 2, 2015 02:47 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
Sep 1, 2015 09:16 AM
