FAIL: My windshield washer reservoir (or something in the piping) has sprung a leak...
Old Sep 12, 2008 | 02:53 AM
VenTTed's Avatar
Default FAIL: My windshield washer reservoir (or something in the piping) has sprung a leak...
Finally figured out that my fluid is leaking from somewhere. Where/how is the best place to test? What component is most likely to have failed?
I'll take off the wheel and liner this weekend to see if I can figure it out (water test/visual), but am curious if there are known failure points.
BTW, I am quite sure that the freakin' cold weather in the NE caused this - probably last year.
TIA
Old Sep 12, 2008 | 03:20 AM
Scenic Driver's Avatar
Default Sell it >>
There aren't many places it could be leaking from, you shouldn't have any problems finding it.
Hey Glen, any interest: <a href="https://forums.audiworld.com/tt/msgs/1785844.phtml">Fall gtg</a>, the rest of the peanut gallery is coming.
Old Sep 12, 2008 | 03:53 AM
TTinCT's Avatar
Rest In Peace
Default put some water in the tank, and then run the pump....>>>
wherever it is wet, is where the problem is (as if you did not know that!!!) could be an alien in the nose, or the connections at the bottom of the tank....with the age, dry hoses is not out of the question....
I a swamped all weekend with sports....otherwise i would help you....
Old Sep 12, 2008 | 05:17 AM
adminisTerTurbo's Avatar
Default do you have a FMIC and disabled aliens
if so it's probably the headlight washer pump. mine separated from it's housing. unplugged it from power ad put it back together. all better.
Old Sep 12, 2008 | 06:15 AM
vicious circles's Avatar
Member
Default having my tank replaced this morning...
leaked two years ago under the tank - hours after I read a post about this problem!
had it checked, pressure tested, no leaks found.
Worked for a couple of months, leaked again.
Old Sep 12, 2008 | 06:30 AM
SparTTan's Avatar
Default The sleeve that the headlight washer pump fits in tends to crack.
Happened to me (twice). Here's the common failure point:
<img src="http://www.msu.edu/~lytleric/IMG_0840.JPG"><ul><li><a href="https://forums.audiworld.com/tt/msgs/1503588.phtml">Follow these links</a></li></ul>
Old Sep 12, 2008 | 07:16 AM
Default that's EXACTLY what happened to mine!
i put some duct tape on it and shoved it back in.
Dville
9
Apr 5, 2020 10:45 PM
Harleyguy
Feb 15, 2017 01:02 PM
musantemike
Oct 15, 2009 08:47 AM
Achen
Dec 29, 2003 03:09 PM
RonDog
9
Aug 21, 2002 10:18 AM
