New name...and a question
Ok whats the easiest way to change out the turbo outlet pipe? I did it once before, but I had a hell of a time! So I was doing a little time trial the other night and I must have not tightened the bottom strap enough; because I blew it off the turbo...oops... So, now I have the fun time of puting it back on.
Inlet, pull the strut bar and reach down behind the engine with a mini ratchet and a deep 7mm socket in your left hand. You do it pretty much by feel while bear hugging the motor..
Outlet? loosen the Turbo out Pipe clamps, get the hose in position and tighten all clamps..
