Check engine light and dip stick shows oil 1" over fill mark
Old Sep 16, 2008 | 10:27 AM
Preservation (Axel)'s Avatar
New Member
Default Check engine light and dip stick shows oil 1" over fill mark
This is my A6 3.0 by the way. Had the oil changed about 3K miles ago and it always read normal on the stick ( at each gas up). Checked it 3 times after check engine light went on (level ground)and it always read the same 1" over. What you think ?
Old Sep 16, 2008 | 10:30 AM
OldSchool AG's Avatar
Senior Member
Default blown head gasket
but I hope not!
Old Sep 16, 2008 | 10:33 AM
New Member
Now it ran just fine for 2mi. till I got home and still runs smooth.
Old Sep 16, 2008 | 10:35 AM
Senior Member
Default that's good
my advice... if you're absolutely sure it's high on the stick, do an oil/filter change, and keep an eye on it.
what code is it throwing? could be unrelated to the oil level.
Old Sep 16, 2008 | 10:40 AM
New Member
Don't know code at this time, I'll find out & do change, Thanks for info.
Old Sep 16, 2008 | 02:46 PM
David_TT225QC's Avatar
This is probably a stupid post, but if the PCV valve was bad, could pressure push oil up the tube?
quico_c
Q5/SQ5 MKI (8R) Discussion
Jun 14, 2011 01:59 PM
subliminal image
Dec 21, 2008 05:28 PM
TJR178
Nov 2, 2006 12:11 PM
pablo1
May 14, 2004 07:02 PM
netsatwork
Audi 100 / A6 (C4 Platform)
Jul 12, 2003 05:56 PM
