anyone have a in depth cut-away of 225 engine?
Old Sep 16, 2008 | 05:48 PM
FijiTT's Avatar
Default anyone have a in depth cut-away of 225 engine?
or illustration
Old Sep 16, 2008 | 06:13 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Here's something.....>
<center><img src="http://www.audistory.24max.de/jroes/pictn/5vturbo.jpg"></center><p>Mosey around on the Google images site...There may be more..<ul><li><a href="http://images.google.com/images?gbv=2&amp;ndsp=18&amp;hl=en&amp;q=1.8T+cuta way&amp;start=0&amp;sa=N">Google images</a></li></ul>
Old Sep 16, 2008 | 07:00 PM
FijiTT's Avatar
Default ok second question
i was looking around in my engine bay with a flash light and i could see a hole and some gear teeth... from the picture you posted it looks like it might be my flywheel. Should there be a plug there or hose or what? should i be worried??
Old Sep 16, 2008 | 07:09 PM
MarTT's Avatar
Default There is a plug that is supposed to go there, but not necessary.
If you'd like to replace the plug, look around the engine bay, it may be hiding somewhere. Or check the link to order a new one.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1557909.phtml">https://forums.audiworld.com/tt/msgs/1557909.phtml</a</li></ul>
Old Sep 16, 2008 | 07:12 PM
FijiTT's Avatar
wow that was quick. thanks!
Old Sep 17, 2008 | 05:32 AM
TTrollin''s Avatar
New Member
that's because it's been discussed about a hundred times and is easily found using the search
OWDLVR
Sep 5, 2007 02:55 PM
TurboQuattro
Auto Detailing Discussion
Feb 15, 2007 02:35 PM
4knfast
Jan 9, 2003 03:49 PM
jeff28
Feb 12, 2002 08:11 AM
Jason Chen
9
Nov 30, 2000 12:03 PM
