searched and couldnt find...part # for lat accell sesnor
Old Oct 27, 2008 | 05:28 PM
sims159914's Avatar
Default searched and couldnt find...part # for lat accell sesnor
Could someone help me out here. I found one PN in the FAQ that said it could be either, but no luck when I searched the # online.
Old Oct 27, 2008 | 05:50 PM
MarTT's Avatar
Default Good luck, it's a confusing mess to me. Yaw, transverse, lateral, whatever it's called.
This link might help if you have not seen it. The part number and location seems to be variable depending on the car.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1192871.phtml">https://forums.audiworld.com/tt/msgs/1192871.phtml</a</li></ul>
Old Oct 27, 2008 | 06:02 PM
sims159914's Avatar
Default did not see that one.....
Mine is a 2001 225. Although I am throwing a code for the lat, not the long sensor. Do you know if the zeroing procedure is the same? I would hate to have to go to the dealer and get changed an arm and a leg to change a simple sensor.
Old Oct 27, 2008 | 06:15 PM
MarTT's Avatar
Default I don't think there is a procedure like that for the lateral. Check your email for more.
If you can narrow down the exact part number and location on your car, then get the part, you can likely change it out yourself.
This picture shows where the G200 is integrated with the other sensors but for model year 2002. Note that some 2001 owners have found the G200 as pictured, though. Yes, confusing.
<img src="http://images115.fotki.com/v681/photos/4/41970/1982850/longaccelsensorG2512002-vi.gif">
Old Oct 27, 2008 | 07:00 PM
SparTTan's Avatar
That's a great post. Should go in the FAQ.
Old Oct 27, 2008 | 07:07 PM
SparTTan's Avatar
That's where it is on my late 2001.
Old Oct 27, 2008 | 07:10 PM
MarTT's Avatar
Yes it is - I added the link in the appropriate FAQ section.
Old Oct 27, 2008 | 07:31 PM
sims159914's Avatar
OK...Ill check under the dash.....
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 27, 2008 | 10:03 PM
kingfishgrapejam's Avatar
Default It was there on my 225q 01 and on my friends 01 180 fwd. I didn't have to do any zeroing procedure
on either.
Old Oct 27, 2008 | 10:06 PM
I used 1j0907651a in a part search on geniunevwaudiparts.com $125
MarTT
Apr 24, 2010 07:10 PM
4corners
Feb 5, 2008 01:53 PM
kritzer007
Nov 22, 2005 10:20 AM
M_HO
1.8T Discussion
Nov 1, 2005 11:46 AM
rjt
Dec 29, 2004 05:02 AM
