AirbagSystems reset - Airbag light still on!! ??? :(
Old Oct 31, 2008 | 12:50 PM
TTsumibishi's Avatar
Default AirbagSystems reset - Airbag light still on!! ??? :(
Hi everyone,
Recently had Airbag Systems reset my airbag module, and I installed it today and cleared the codes (yay - no more Airbag fault code!!) but <b>the airbag light won't go off!!</b>
Any suggestions?
Dave
Old Oct 31, 2008 | 12:53 PM
carsluTT's Avatar
Default ull love this ...........
time to get a new air bag controller and make sure u don't scan it ever again. its kind of a odd problem that once the light comes on the controller stores a permanent code and has to be replaced. most vag-com's will prompt you about this issue before they will let u scan a air bag controller even.
i get lots of guys who scan the air bag in there car just for grins cuz they have a vag-com. then get all bent the light never gos off again.
Old Oct 31, 2008 | 12:54 PM
Default Will the airbag still function even with the light on?
Or is it completely inoperable?
Sigh...if I don't scan it, how can I find out what's wrong??
Old Oct 31, 2008 | 01:00 PM
jhoeppel's Avatar
Default Try this first... >>
Contrary to carsluTT's experience, I've scanned my airbag control module many times without breaking anything. Vag-com triggering an airbag module's fault code is specific to certain VW models, but not our TTs according to the Ross-Tech site.
But I did have a problem with the airbag light in the instrument cluster, which is why I scanned the control module in the first place (the light stayed lit or flickered on cold starts for several minutes even though the airbag module never had any stored codes).
Try this: scan the airbag module and instrument cluster for fault codes. You probably won't find any. Even if you find no fault codes, press the [Clear codes] button anyway. This may turn off the airbag light--it fixed my airbag light problem.
If not, you may have to follow carsluTT's advice and replace the module.
~john
Old Oct 31, 2008 | 01:33 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
I have scanned my airbag module many times. Light hasn't come on.
Old Oct 31, 2008 | 01:40 PM
carsluTT's Avatar
Default it will work just fine, the light is just retarded. some times it just gos off on its own
things were really touchy in early year cars
Old Oct 31, 2008 | 02:53 PM
What goes off on its own..the light or airbag?
Old Oct 31, 2008 | 02:55 PM
Default Tried that a few times...I also pinged airbagsystems, see if maybe someone else reported it...
Crossing all digits.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 1, 2008 | 08:45 AM
carsluTT's Avatar
Default the light in the dash. the system always works fine either way. its just the silly light.
its got a mind of its own for some reason.
shazoo
Aug 18, 2023 05:39 PM
Projekt 8E
Mar 3, 2011 08:35 PM
joeycuccaro
Nov 7, 2005 03:53 PM
JSAudi100
Aug 24, 2004 01:19 PM
edial
Nov 14, 2003 05:58 PM
