Two clips on hood latch cable loose: pinched and replaced; four corner plastic screws on belly pan
Old Nov 2, 2008 | 02:00 PM
Milpower's Avatar
Junior Member
Default Two clips on hood latch cable loose: pinched and replaced; four corner plastic screws on belly pan
tightened; bolts on engine and transmission mounts checked for tightness (they were tight); checked heat shield behind turbo and also thin medal shield over tie rods (I think): sprayed the latter with a little bit of undercoating (if it gets too hot, it will just heat up and burn off); and, moved the SAIP air intake hose to another location.
ONE of these stopped not just the added vibrations from shifting the sub-frame, but now I don't hear the one that's existed since getting the car!
CD player, glove box, and right front area of dash still vibrate, but have a fix for all of them (graphite, inspection, and felt, respectively).
And, BTW, replaced the fuel injector seals in about 15 minutes from start to finish. Is easy when the right parts are sent!
Old Nov 2, 2008 | 02:06 PM
MarTT's Avatar
Default Did you do this do the fuel injector rail? See pic >>
Rid yourself of all the plastic guides . . . cleans up nicely.
<img src="http://images41.fotki.com/v1346/photos/4/41970/6648249/DSCN9840-vi.jpg">
Old Nov 2, 2008 | 02:09 PM
Blue TTop's Avatar
IM looks great. Is that a ModShack powdercoat job?
Old Nov 2, 2008 | 02:21 PM
MarTT's Avatar
RE: ModShack powdercoat job - yes, I was an early adopter.
Old Nov 2, 2008 | 02:22 PM
Milpower's Avatar
Junior Member
Default Not yet, but planned. BTW, your pic indicates my FPR is on backward (nipple). Will go look at mine
and see if I can't spin that sucker around and remove some hose.
Old Nov 2, 2008 | 02:28 PM
MarTT's Avatar
Default The FPR nipple points towards the battery just a tad. Position it so the hose is comfortable.
<center><img src="http://images42.fotki.com/v1314/photos/4/41970/6648249/DSCN9837-vi.jpg"></center><p>
Old Nov 3, 2008 | 04:24 AM
TTinCT's Avatar
Rest In Peace
still looks great Marty! ;-)
Old Nov 4, 2008 | 08:49 AM
ClarkSJ's Avatar
Default I found torque on dogbone to be critical in preventing vibrations
When I put my Polyflex bushings in. Probaly the same for the engine and tranny mounts. You need some serious muscle to torque the stretch bolts to spec +90 degrees.
 Pouria Savadkouei
 Michael S. Palmer
AudiSpaulding
Nov 16, 2007 10:43 AM
UrScubed
Audi Original "S" Cars
Dec 23, 2006 11:48 AM
polishadonis
10
Nov 15, 2005 05:31 AM
1.8TQ99.5
May 18, 2004 08:07 AM
Greg PAW
12v V6 Discussion
14
Feb 6, 2004 04:57 AM
