Ok, after months of waiting plugged my liquidTT in and found that it only shows up to 2000mbar.
Old Nov 5, 2008 | 06:09 AM
maaliish's Avatar
Default Ok, after months of waiting plugged my liquidTT in and found that it only shows up to 2000mbar.
Is there a setting I need to change? Also, I'd like to see the reading in PSI rather than mbar.
Old Nov 5, 2008 | 06:24 AM
TTinCT's Avatar
Rest In Peace
Default there is a limit in VAG, and a delta for computing boost too>>>
like 750mb or so.....I wonder if the Liquid TT has some limits in the current rev?
Old Nov 5, 2008 | 06:26 AM
maaliish's Avatar
Default yeah, but limit in VAG is 2500mbar not 2000. My vag-com always shows readings above 2000.
This thing is useless to me if it doesn't get to 2500.
Old Nov 5, 2008 | 06:41 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default What software version are you on?
Imperial units were added in 1.05. There is also a big turbo setting that will allow higher HP and boost plots axes. The current version is 1.07, though most in the field are on 1.06.
Software updates are done for the cost of shipping only - e-mail me if you want to upgrade yours. You can see the revision history at the link.<ul><li><a href="http://racediagnostics.com/cms/index.php?page=upgrades">RaceDiagnostics liquidTT Firmware Revisions</a></li></ul>
Old Nov 5, 2008 | 07:12 AM
maaliish's Avatar
email sent.
Old Nov 5, 2008 | 07:15 AM
Tech Guru
Default Imperial units was included in version 1.06, which is what you should have on your install.
You can select imperial units (meaning boost will be in PSI) under the setup menu.
As for boost, I do not know the max limits at this time, but I believe they are raised if you select the "Big Turbo" function, also in the setup menu. I know this raises the "Y-axis" measurements on BHP and MAF, but I believe boost is affected as well.
Access to the screens is discussed in the user manual linked below.<ul><li><a href="http://racediagnostics.com/cms/uploads/images/pdfs/Racediagnostics%20liquid%20user%20manual%20rev%201 _07%20.pdf">liquidTT user manual</a></li></ul>
Old Nov 5, 2008 | 07:24 AM
TTBlack's Avatar
Junior Member
So is version 1.07 available?
Old Nov 5, 2008 | 07:26 AM
Tech Guru
Default Yes, I was not sure if it was official or not, but it is now listed on RaceDiagnostics' site, so I
can now offer it as well.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 5, 2008 | 07:39 AM
TTBlack's Avatar
Junior Member
I'll be sending mine out to you soon!
Old Nov 5, 2008 | 07:42 AM
Tech Guru
Please e-mail me your serial number so I am sure to have the new version ready.
