Ok, after months of waiting plugged my liquidTT in and found that it only shows up to 2000mbar.
Is there a setting I need to change? Also, I'd like to see the reading in PSI rather than mbar.
What software version are you on?
Imperial units were added in 1.05. There is also a big turbo setting that will allow higher HP and boost plots axes. The current version is 1.07, though most in the field are on 1.06.
Software updates are done for the cost of shipping only - e-mail me if you want to upgrade yours. You can see the revision history at the link.<ul><li><a href="http://racediagnostics.com/cms/index.php?page=upgrades">RaceDiagnostics liquidTT Firmware Revisions</a></li></ul>
Imperial units was included in version 1.06, which is what you should have on your install.
You can select imperial units (meaning boost will be in PSI) under the setup menu.
As for boost, I do not know the max limits at this time, but I believe they are raised if you select the "Big Turbo" function, also in the setup menu. I know this raises the "Y-axis" measurements on BHP and MAF, but I believe boost is affected as well.
Access to the screens is discussed in the user manual linked below.<ul><li><a href="http://racediagnostics.com/cms/uploads/images/pdfs/Racediagnostics%20liquid%20user%20manual%20rev%201 _07%20.pdf">liquidTT user manual</a></li></ul>
