Transmission light up?
Thanx
as for the selector in the dash, yes you can change the lights in there and it is easy if you know how to solder things.
The only reqireing i did was in each little bulb housing (such a pain but keeps cluster untouched). Since it was 12volts i did need to use a resistor to drop it to 2.2 volts (about 20mA) across the lamp. Those pics should be in that same post.
The pic is me hotwireing the cluster with a 12volt source on one side, dont have a clock but it is just as bright. One of these days i will take a pic with it at full brightness. The good thing is that since i did red LEDs it doesnt hurt to look at them or the color doesnt fade to pink. Also that picture is on 1/30 shutter speed i believe, near dim daylight.
