new 90 Quattro owner needs help
You need to have a competent audi mechanic look at this car and tell you what all is wrong. If the water pump is bad, you could lose the timing belt soon and you'd really be in a world of hurt.
There are a whole list of things - search for "Fuel System" or "fuel components" - and you will find many posts. My pic poster has several drawings of the fuel components.
You also need to find out about the Temp Warning Light. Could be a bad sensor (low coolant sensor)at the bottom of the coolant tank or something else. The ECU will not feed the correct data if the coolant sensor is bad - these are cheap & easy to replace.
But you really need to get a good overall picture of what's going on. Sounds like several things are bad - including one that could be major if your timing belt breaks (it drives the water pump).
Thanks
Nick
