My engine just died - please help to troubleshoot!
Old Mar 17, 2004 | 06:24 PM
another_90CS_quattro's Avatar
New Member
Default My engine just died - please help to troubleshoot!
Dear All!
My 90CS quattro V6 engine just decided to quit.
I came home from work one hour ago, everything was OK. Now my wife wanted to go to pick up our kid, started the engine, started moving and engine died.
Tried to start it again - it starts but dies almost instantly. Like there is not enough fuel or something.
Please help me to troubleshoot this problem. What should I check first?
Thanks a lot.
--another_90CS_quattro.
Old Mar 17, 2004 | 06:40 PM
2nice4ya's Avatar
New Member
Default troubleshoot!
hello. look under you audi when some one is on II possition of the key as when u just see your dash lights come on, when they do hear if your fuel pump is working...it`s gona sound just for like 2-3 deconds and then it`s gona go off. if u don`t hear anyting thats a spot to go for.
Old Mar 17, 2004 | 06:47 PM
2nice4ya's Avatar
New Member
Default I OWN A 90 CS TOO.
HERE SOME SPOTS YOU COULD LOOK FOR BEFORE THINKING TAKIN IT TO DEALER....CAN YOU SEE LIGHTS ON DASH BOARD INFORMATION?DID U CHECKED THE FUSE INSIDE UNDER THE DRIVERS SIDE?(BIG ONE)...........HOW ABOUT ENGINE FUSE INFRONT (ENGINE)...CAN U BE MORE SPECIFIC?
Old Mar 17, 2004 | 06:50 PM
Hidshadows's Avatar
Default we need a cabinet member to regulate this insanity
was it really that IMPORTANT
Old Mar 17, 2004 | 06:53 PM
Bubuski's Avatar
Default ...
Caps lock offend a few on this board. Easy on it
Old Mar 17, 2004 | 07:10 PM
88audi90_Q's Avatar
New Member
Default ive never worked on the v6 but if it was an NG ide ask u to check the following
vacuum lines.. could be a nice leak that jus got worse. another thing is like ricardo said, turn the key, jus put it into contact, dont try and crank it, turn it, and listen for the *buzzzz* from the fuel pump, if u dont hear it, it could be electric, or the pump was just never changed..
it could also be ur fuel filter, if its never been changed, its got alot of nasty stuff stuck in it, and eventually get into the lines, try putting sum fuel line cleaner if u get it started.
another thing u could check , not sure how it is on the v6 but on the ng , u can loosen a hose from the fuel distrib, and check if its shooting enuff fuel, u could also take off the injectors, and check if they r shootin equal fuel..
if ur a do it urselfer, u could try all of these things, first thing ide do is buy a filter * if u know it hasnt been changed* and change it, filters r way cheaper than pumps
another thing that might help is the search section of the forum
https://www.audiworld.com/search/
Old Mar 17, 2004 | 07:53 PM
20VT90q's Avatar
That has to be the most least helpful advice I have ever read on this forum and it was in CAPS!
Old Mar 17, 2004 | 08:38 PM
TabulaRasa's Avatar
It starts, it runs, but dies quickly. Can you keep the engine running if you floor the throttle?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 17, 2004 | 08:39 PM
Julian_B's Avatar
Junior Member
Is your charging system working properly????
Old Mar 17, 2004 | 09:05 PM
TabulaRasa's Avatar
Default Don't think that's the problem.
It starts up, it does right away, doesn't sound like the batt. or the alt.
If the alternator was bad, the car would drive until the battery was run down.
If the battery was bad, it wouldn't start.
