OEM thermostat is 87 degrees Celcius...does it make any sense to run a lower temp thermostat?
What applications would benefit from this, if any?
One other thing that will affect temp is whether you have you belly pan on or off.
And yes fuel mileage does go down somewhat, but its worth not overheating you engine on a hot, trafficky day.
Sry just realized your in NY, run the 87C for the winter, and if you want switch in a 80C in the late spring early summer.
the thermo on the V6 is not in a nice spot so changing it out yearly would be a real pain. I have never seen anything other then the 87c thermo for sale, but they might offer it at a dealer?
want a cooler engine, slap some redline water wetter in it, my temp gauge never goes over the heavy dash at about 9 o'clock and usually depending on the temp outside runs at the click below it.
