Replacing cat on '89 90 and strange buzzing...
Old Oct 6, 2004 | 08:01 PM
FortySixAnd2's Avatar
New Member
Default Replacing cat on '89 90 and strange buzzing...
Thanks to the members on this forum I think I have found the cause of my power loss: catalytic converter is bad. It rattles and makes all sorts of wonderful noises when the car is running and when I poke it with a stick(suggestion by forum members). I am going to have a shop check it out to make sure that is the problem.
Anyways I did some searching and have found the best/cheapest thing to do is buy an aftermarket cat for ~$65 from summit.
-All I need to do is find a shop that will cut the old cat off and weld the new one on correct? Do I need to have the rest of the exhaust checked out (I don't know much about car maintenance), some said a broken cat will clog up the exhaust...
-Also, I've had this problem since I bought the car last year, but forgot to ever mention it. In the rear under the car (around or at the "suitcase" as I have heard it called), there is a buzzing noise. It sounds more like an electronic buzz rather than a mechanical noise though. What exactly is the "suitcase" for and what does this buzzing mean?
Aerowill
Jul 25, 2007 02:34 PM
blakely
Jan 26, 2005 07:08 AM
shwndh
30v V6 Discussion
Nov 25, 2004 09:03 PM
Ghostfire
May 6, 2004 08:52 AM
DanA100
Misc. Models Discussion
Jul 9, 2001 10:51 PM
