Power steering pump belt (I think it's called the VBelt?) question...
Old Apr 21, 2005 | 05:32 AM
Hokie - STI avant's Avatar
Default Power steering pump belt (I think it's called the VBelt?) question...
I've noticed a few cracks in the belt that spins the PS pump, alternator, etc. How hard is it to remove the belt completely? I've used the tensioner to slide the belt off the PS pulley before, but I wasn't sure if the rest of the belt simply slid off. Do I have to remove any brackets?
Thanks,
Mike
Old Apr 21, 2005 | 05:43 AM
520's Avatar
520
Default No, tensioner only, 10 minute job....oh wait....
I don't remember now if you have to remove some plastic covers off the front of the engine, but still, its super easy!
Old Apr 21, 2005 | 07:10 AM
quattro.pilot's Avatar
AudiWorld Expert
Default ya, plastic belt covers off (as A_CQ said) and then use a prybar underneath the tensioner...
you need to pull-up (so clockwise direction) in order to release tension. Getting it off is pretty easy, as if the belt is at all worn/loose it practically falls off once the tensioner is disengaged. Gettin the new (tight) belt back on -by yourself- properly is a bit tricker...easiest if you have a helper to just hold up on the bar.
check yah later
Old Apr 21, 2005 | 07:13 AM
520's Avatar
520
Default pry bar? Just use 8 or 10mm hex in its original slot for releasing the tension
No risk of braking something. When putting new one on, put it everywhere besides the PS pulley, then release yension on the tensioner and pull it over the PS pulley.
Old Apr 21, 2005 | 07:25 AM
AudiWorld Expert
Default sorry, my mistake. now that I remember ya, i used an 1/2 impact socket on the end of my flex handle
but at 8:00 all that came to mind was 'prybar' heheh =S
Old Apr 21, 2005 | 07:33 AM
520's Avatar
520
just watching out for Hokie....pry bar slamming his nose wouldn't be fun , or would it?
Old Apr 21, 2005 | 07:41 AM
AudiWorld Expert
maybe fun for us... haha
Old Apr 21, 2005 | 08:54 AM
I know how to use the tensioner... I've replaced the PS pulley before.
 Pouria Savadkouei
 Michael S. Palmer
jimboney
Mar 11, 2006 03:43 PM
thanatos
Feb 25, 2005 10:11 AM
salpinx
Apr 27, 2004 01:34 PM
Ritz
Feb 17, 2004 02:12 AM
