troubleshooting starter selenoid wire
Old Apr 26, 2005 | 10:15 AM
Canada90's Avatar
New Member
Default troubleshooting starter selenoid wire
I seem to have a break in the wire from the ignition switch to the starter selenoid. Does anyone know the routing of that wire, and what to check for to determine where it is losing continuity?...thanks.
Old Apr 26, 2005 | 10:17 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Auto or stick? Huge difference.
Old Apr 26, 2005 | 10:19 AM
Canada90's Avatar
New Member
Default Re: Auto or stick? Huge difference.
automatic
Old Apr 26, 2005 | 10:23 AM
Regenmeister's Avatar
Senior Member
Could be the cutoff switch at the gearlever.
Old Apr 26, 2005 | 10:25 AM
Canada90's Avatar
New Member
Default Re: Could be the cutoff switch at the gearlever.
any ideas about how to check it/where to look?
Old Apr 26, 2005 | 10:38 AM
Senior Member
Default You'll need the Bentley Manual to do this. Electrical schematics are....
are important to have when hacking around. Without it you are gambling. Would need to take console off to do an electrical check on components.
Old Apr 26, 2005 | 10:53 AM
Brdman*'s Avatar
you sure it isn't a bad ignition switch?
Old Apr 26, 2005 | 02:10 PM
Canada90's Avatar
New Member
Default Re: you sure it isn't a bad ignition switch?
replaced it (it was broken as most of them are when you are having trouble), but the new one made no difference.
 Pouria Savadkouei
 Michael S. Palmer
Blewtoon
Mar 16, 2009 10:46 AM
tmorales
Nov 15, 2007 12:45 PM
lesk123
Aug 5, 2007 06:59 AM
audi 273
Nov 5, 2006 06:02 PM
Bryce
Oct 16, 2002 09:17 PM
