I am fed up, car failed emissions again... high on HC @ idle again
Old Oct 18, 2006 | 04:22 PM
Snow Trooper *Swiss*'s Avatar
Senior Member
Default I am fed up, car failed emissions again... high on HC @ idle again
either i have over looked something, or this shop is shady. I doubt the later. there is no logical reason for it to be failing on HC.
Only possible thing in my mind is if it is infact running lean at idle. but it shouldnt be. it also has been getting poor mileage. that makes no sense either. I am about to put some of that guaranteed to pass BS in it and get the hottest plugs i can find.
>:X
i have done the following:
New O2 sensor
new air filter
complete cleaning or throttle body and intake
Cleaned MAF sesnor with Isopryol alcohol
new plugs
new cap and rotor
new wires
fresh oil and filter
cleaned ISV
new thermostat (was running cold)
ran seafoam through the motor (intake)
run techron through the motor (fuel)
unbolted the cat, looks to be in perfect condition
traced every vacume line, no leaks
cleaned full PCV system
only red flag i have found it that when the oil cap is removed the motor does not die, doesnt sputter, doesnt do anything. shouldnt it die from the vacume leak created? yet i dont think it has tuned itself for a massive leak because opening up any port on the intake manifold such as the ISV inlet kills it.
this thing is pissing me off, i only have about an hour at a time to screw with it and i am drawing a blank on why the damn HCs wont come down.
Old Oct 18, 2006 | 04:32 PM
Just Paul's Avatar
Default Did you adjust the idle mixture?
There's a series of things to this step see Bentley for details... Maybe you have a pissing injector or something weird. Have you given it the Italian tune up?
HC is unburned fuel right? so it's running rich. Check the plugs for signs of this. But like I said it could be poor fuel atomization.
Old Oct 18, 2006 | 04:39 PM
Senior Member
Default I have always been taught that HC at idle is a lean condition, i have not touched the mixture at all
plugs are all a little too clean, this is telling me lean condition. there is no unburnt fuel coming out the exhaust in anny excessive amounts, so i am ruling out misfires
Old Oct 18, 2006 | 06:53 PM
10Mghzs's Avatar
Default Re:Only if its as lean miss
Do you have a recent cat. in the car. I used to be a cal emissions inspector. I used to have a lot of problems with the 7A engines. Their hard on the converter. I would try replacing it.
Old Oct 18, 2006 | 10:27 PM
Senior Member
Default uggghhh
i guess thats one of the next steps
Old Oct 18, 2006 | 11:19 PM
Merkin's Avatar
AudiWorld Expert
NOx is lean
Old Oct 19, 2006 | 05:07 AM
Regenmeister's Avatar
Senior Member
Default Your injectors are shot! Hitachi crap is killing you. Change over to 034's.
Failed HC means unburnt fuel...not a lean condition.
Your injectors are dumping too much fuel into engine. Sure sign of it?.....go too back of car while car is running...does your eyes sting a little or you smell fuel back there? Bingo!
Your cat is probably shot too from the unburnt fuel flowing thru there.
Old Oct 19, 2006 | 05:58 AM
10Mghzs's Avatar
Default Re: Oxides of Nitrogen are related to heat. During if it pings (detonation)
Nox goes way up. But if the engine misfires you're going to get a big gulp of HC. HC is unbured gas. HC also relates to how efficient the engine is newer engines produce less HC than a worn engines, not saying that yours is worn out. That is one of the factors in the Japans emissions policy of engine change at 30k.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 19, 2006 | 11:47 AM
Senior Member
Default wouldnt the plug be nasty looking if it was rich and pushing unburnt fuel around?
i planned on getting o34s kit, just dont have the cash right now.
btw- your o2 write up was a big help as i had never done one on this chassis, thanks
Seanm
Audi 100 / A6 (C4 Platform)
Sep 7, 2017 12:34 PM
jcrampton
Apr 21, 2011 05:22 AM
lrrr
Dec 1, 2006 06:33 PM
GettinAudiHere
May 22, 2006 01:09 PM
Jeff Doble
Feb 21, 2003 02:40 AM
