Relay operation question....
the relay on the left is how I learned to wire a relay.(the posative is not a circut still under "load" by a light or something...it is something like the old posative connection to a headlight that is no longer used to power the headlight..it is used as a trigger, like my hid setup)
I was wondering if the method on the right will work?? can you have a relay 'trigger" on a circut that has a light bulb on the end...and the bulb will still work??? (the light bulb is ovousley grounded, I just frogot to draw that)
If this does not make sence I can explaine it better
puttin a auto dimming mirror form a Diville in the 90
If you have a device that can be run off the low current on the left side, just use a switch and not a relay.
In your right-hand diagram the light bulb would be like an indicator light to tell you whatever high-current device is attached to the high-power side is turned on.
I want to run a new power to the rear view mirror that I am putting in...and have it turn on and off with the switched 12V, so.. I was wondering if the signal (+) from the guages lights could be used as the "trigger" for the rear view mirror via a relay???
hope that makes sence
<a href="http://photobucket.com/" target="_blank"><img src="http://i4.photobucket.com/albums/y145/pharoah007/DSC01649.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
