Wiring my Amp.
Old Oct 24, 2006 | 02:53 PM
Audi_8890's Avatar
New Member
Default Wiring my Amp.
I'm going to install and well I was wondering if any of you guys would know how to wire it specifically to the Audi 90. My last amp I installed seemed to not have a very good ground and would always stop working for my. Where's a good spot in the trunk to ground it to? Any feedback would be great!
Old Oct 24, 2006 | 03:17 PM
SCarGo02's Avatar
Default There's nothing specific for wiring an amp in an Audi...power, ground, remote, RCAs, wires to...
...speaker(s)...?
Old Oct 24, 2006 | 05:19 PM
YucatanAudi's Avatar
Default A good spot is one with bare metal and where the terminal is securely screwed down.
Add a little dielectric grease to insure that it doesn't corrode and you are done. If you had a problem with a "good ground," then the metal wasn't bare, the screw wasn't tight, there was corrosion, or your terminals were not properly crimped, wires properly spliced, etc.
"Audi-ness" has little to do with it really. Aside from that, if do a search, you will come up with all sorts of comments.
Old Oct 24, 2006 | 07:48 PM
Merkin's Avatar
AudiWorld Expert
I used a threaded area by the spare tire, why drill when a grounding terminal is built in
Old Oct 24, 2006 | 08:30 PM
booogs's Avatar
Senior Member
in the trunk under the carpet.....you should be able to pull it up and ground it there.
Old Oct 24, 2006 | 09:49 PM
Audi_8890's Avatar
New Member
Default Thanks for the help.
I know its pretty much the same thing when it comes to wiring an amp in most cars but just wanted to see where were some good grounding points.
cfsdir
Sep 3, 2007 08:52 PM
Endoplasmic
Dec 29, 2004 09:36 AM
96A42.85SPD
Feb 20, 2004 08:47 PM
LilAudi2002Girl
Aug 14, 2002 07:45 AM
Kirath ¾-B0§t0n
Jul 10, 2001 12:19 PM
