Car will not start... pulled codes... baffled...
Old Nov 1, 2006 | 01:11 PM
blackbart's Avatar
Member
Default Car will not start... pulled codes... baffled...
Okay...
Car: 1990 80 4 cylinder will not start. Was warming it up the other morning and after runing for 3 or 4 minutes it just died and has not started since. Turns over just fine and fires up, but dies after 2-3 seconds.
Codes: 2312 - Cooland temp sensor. This was the only code that came out before all 0's (tried it twice to make sure).
Baffled: Why would a coolant sensor keep the car from starting?
Any input appreciated
Old Nov 1, 2006 | 01:19 PM
AudiSport4000's Avatar
Default Faulty sensor
It will make the ECU think the car is either really hot or really cold, therefore adjusting the mixture to compensate. A new coolant sensor should hopefully remedy this problem.
Old Nov 1, 2006 | 01:22 PM
blackbart's Avatar
Member
Default OK... which sensor?
The one at the bottom of the radiator or the one on the block near the cylinder head?
Old Nov 1, 2006 | 01:51 PM
Default Im unsure, hopefully somebody else...
May be able to help. Its not the one on the radiator, that controls the radiator fans. IIRC, there are 2-3 coolant sensors on the 4cyl. The sensor *may* have a plug WITH metal clip on it. It also may be the same sensor the 4000 quattro uses.
Hopefully somebody with more 4cyl Audi experience knows.
Old Nov 1, 2006 | 02:19 PM
CastleCQ's Avatar
New Member
Default the one at the back of the block is for the computer
the one on the radiator is for the fan/gauge. Try ohming it out, I believe it should be between 200-300 at temp. I could be off with my numbers and I don't have my bentley handy.
Good luck
tybmw
Dec 16, 2006 04:28 PM
Sully
Jul 25, 2006 01:24 PM
f3d
NY / NJ / CT Discussion
Sep 26, 2005 07:08 AM
brrman
May 19, 2003 01:10 PM
a4neil
Feb 18, 2002 09:06 AM
